Gearboxes for Scirocco 2 1.8 l
SciroccoNorway
Beitrag von SciroccoNorway »
Hello.
I have two gearboxes for my Scirocco 2, 1.8l. 1989 mod. My engine is type JH. But I discovered that it is different markings on gearboxes. One is labeled ACD4 and the other is labeled AUG3. Both are 5 speed, and I think both fit on JH engine, but anyone know if there is any difference on these gearboxes?
Regards
Ragnar
OSLer
AW: Gearboxes for Scirocco 2 1.8 l
Beitrag von OSLer »
Hi Ragnar, only minor differences in second, fourth and fifth gear, this should help: http://www.sciroccoforum.de/forum/conte ... 8-Getriebe
greets
Lars
SciroccoNorway
Thank you Lars.
Then I can conclude that attach to the motor and drive shafts are the same on ACD4 and AUG3?
it's nice to be a member of the sciroccoforum and get good answers :-)
Regards Ragnar
OSLer
Beitrag von OSLer »
Yes, these two gearboxes are completely interchangeable and compatible with all the parts bolt onto it. Don't forget to change the oil, it really makes a difference.
Castrol TAF-X (now called Syntrans Transaxle) 75W-90 is a good one:
http://msdspds.castrol.com/bpglis/Fusio ... RA39_0.pdf
greets
Lars
