Question about MK2 tail fog lights????
General discussion for Scirocco owners
Doug Teulie
Beitrag von Doug Teulie »
Hello all and happy new year. (I got your cards, thanks)
I want to know:
Question 1, Do the tail fog lights on a Euro LHD MK2 Scirocco illuminate only when the regular tail lights are on?
Question 2, Do both left and right tail fog sides illuminate on Euro models?
Question 3, Do the tail fog lights illuminate differently on UK models?
I have a US spec car and I am adding defeat switches to my tail fog lights.
In the US they run the main power wire to the US/NA side markers, don't install the tail fog light bulb and then run a jumper to the regular tail lights at the connector.
In order to install the tail fog bulb you have cut holes in the rear lens backing cups. Then you have to cut the trace between the side marker and the tail fog and add a jumper between the tail lights to the side marker. After that you pull out the connector contacts and change the positions between the tail light and the tail fog (the primary wire from the harness needs to connect to the tail light). Now you can cut the jumpers and add a switch to the tail fogs to turn them on and off. So at this point I want to know if I should use the tail light power wire with a relay or run a separate power wire to the tail. I have to run power in both configurations but it makes a difference at the fuse box,
Thanks.
Doug T (California USA)
76 MK1 Scirocco 1.8 S8V
80 MK1 Scirocco 1.8 S8V
87 MK2 Scirocco 1.8 16V
COB
AW: Question about MK2 tail fog lights????
Beitrag von COB »
Doug Teulie hat geschrieben:H
I will try to answer your questions as good I can.
Q1: Yes, it is required that the tail fog light must not illuminate if the regular tail lights and headlight (not only possioning lights) are OFF.
Q2: No. Only the tail fog light possioned to the middle of the road may illuminate at german/ imho euro models.
Q3: Yes, please refer item 2. ;-)
Hope I could help. ;-)
Doug Teulie
COB hat geschrieben:I will try to answer your questions as good I can.
Thank you.
I have seen some (LHD) cars with both Tail Fog lights on at the same time but passenger side one is not as bright.
Doug Teulie
Doug Teulie
Hi Dirk, No need to go out in the cold.
Do you have the marker bulb in you tail light assembly or is that a reflection?
Doug Teulie
Yes I like the German version best!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Doug Teulie
Dirk hat geschrieben:you will probably need a new keyboard, as your "!" is jammed :-) )
oooops :-)
Tempest
Beitrag von Tempest »
Both tail fog lights illuminate on UK models, at least on my Storm, where I have left the wiring loom totally original. A separate wire leads to the rear fog lights, from the fuse box and fog light switch in dash.
If pics needed, you'll have to wait till tomorrow, when I'm back in the UK again (currently still in Germany :grins: ).
Tempest
My Mk1 Rocco, Rado and 928
COB
Beitrag von COB »
Tempest hat geschrieben: where I have left the wiring loom totally original. A separate wire leads to the rear fog lights, from the fuse box and fog light switch in dash.
Mal eine kurze Zwischenfrage: Hast du davon zufällig einen Schaltplan, den du mal "freimachen" könntest, wo das dann wie verschaltet ist ? Eine 2te NSL halte ich ich für durchaus interessant. ;)
Doug Teulie
I have a question.....
What bulbs are the Sidelights that come on when the headlight switch is at the first "on" position on a UK spec Scirocco?
What bulbs are Dipped-beam headlights that come on at the second "on" position on a UK spec Scirocco? (I think the H4 lo)
