1.8 JH-engine tips?
General discussion for Scirocco owners
Sebastian53b
Re: 1.8 JH-engine tips?
Beitrag von Sebastian53b »
to get more power ,you can also use the airflow sensor disk, fuel distributer and intake manifold from the eg (1.6 gti engine).
______________________
(][__][_]===W===[_][__][)
kapsu
Beitrag von kapsu »
Sebastian53b wrote:
> to get more power, you can also use the airflow sensor disk,
> engine).
Really? I'll keep that in mind.
I have read many texts about the bigger throttle body and changing the ignition distributor from 112hp engine but this was new..
Scirocco GT2 -90, Finland
kapsu
Beitrag von kapsu »
Tempest wrote:
about the full throttle switch..
> >What does the switch do anyway?
> It signals the Lambda control unit to ignore the Lambda sensor
> readings and enrich the mixture.
hmm, so normally it holds back on the mixture becoz of the lambda.. what if you would modify the full throttle switch to be on all the time?
Post Edited (07-20-05 10:49)
Sebastian53b
i hadn't try it but i will, i only read it in a vw-tuning book.
Mr.Burnout
Beitrag von Mr.Burnout »
The easiest way to boost your JH Engine is changing the pistons.
Using EX or DX pistons will boost your Engine up to 105-110 hp, without any more changes.
The difference is that you must use premium gas.
Greetings and have fun
Stefan
Tempest
Beitrag von Tempest »
Can do that, the frequency valve will than permanently run at 50%, slightly rich. Not the best way of tuning the JH, though :zwinker:
Tempest
My Mk1 Rocco, Rado and 928
